bmwkingaudio Posted August 25, 2008 Author Report Posted August 25, 2008 1. audiopulse axis (2500rms, can run at 1 ohm) powered by autotek amp (4000rms, 1 ohm stable) 2. audiopulse ultra (5000rms, dont know if it can be run at 1 ohm or only 2) powered by autotek amp (4000rms at 1 ohm, 2800 at 2 ohm) and ma audio (3600rms at 2 ohm, idk if it can be bridged to 1 ohm, also thats 3600 at 14.4v, so more like 3000 at wat i'll be at) which one? idk y, but for some reason the ultra is callin me Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
bmwkingaudio Posted August 25, 2008 Author Report Posted August 25, 2008 but the ultra is also more than a grand. yea i know. ive decided on the axis, caus i dont hav the money for the extra electrical to power the ultra either Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
bmwkingaudio Posted August 26, 2008 Author Report Posted August 26, 2008 my final descicion is the 15 audiopulse axis (2500rms) wit a autotek 4000.1 amp (4000rms). wired at 1 ohm. i also plan on doin the big 3. any suggestions on batts, alts, and caps? and wat wire size Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
Eric B Posted August 26, 2008 Report Posted August 26, 2008 my final descicion is the 15 audiopulse axis (2500rms) wit a autotek 4000.1 amp (4000rms). wired at 1 ohm. i also plan on doin the big 3. any suggestions on batts, alts, and caps? and wat wire size umm....i wouldnt feed that sub 4000rms... those ti cones like to warm up when fed over rms...jus be easy on the gains and as far as alt get the biggest you can and 2 Powermaster D3100 or Kinetike 2400... no caps and 2 runs of 1/0ga wire 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
bmwkingaudio Posted August 26, 2008 Author Report Posted August 26, 2008 umm....i wouldnt feed that sub 4000rms... those ti cones like to warm up when fed over rms...jus be easy on the gains and as far as alt get the biggest you can and 2 Powermaster D3100 or Kinetike 2400... no caps and 2 runs of 1/0ga wire so the amp choice is fine?, just keep the gain down.. or would a audioque 3500d be better fit? i'll c how big of alt is made for my car, any suggested brands? should i get those 2 batts plus my curent batt? and run the big 3 twice? k. how big or wire to run to the amps and subs Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
Eric B Posted August 26, 2008 Report Posted August 26, 2008 so the amp choice is fine?, just keep the gain down.. or would a audioque 3500d be better fit? i'll c how big of alt is made for my car, any suggested brands? should i get those 2 batts plus my curent batt? and run the big 3 twice? k. how big or wire to run to the amps and subs yea those batts plus your current..you can upgrade your starter too if you wish. and no do the big 3 in 1/0 and run from your front battery 2 runs of 1/0 ga wire to your rear batteries.. me personally would jus run a good 3000rms amp to it... because a autotek4000d to it is jus a bit of overkill imo 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
bmwkingaudio Posted August 26, 2008 Author Report Posted August 26, 2008 yea those batts plus your current..you can upgrade your starter too if you wish. and no do the big 3 in 1/0 and run from your front battery 2 runs of 1/0 ga wire to your rear batteries.. me personally would jus run a good 3000rms amp to it... because a autotek4000d to it is jus a bit of overkill imo ok. my cars current batt is actually in the trunk, idk y but thats how my car is built. so how would the big 3 work to the current batt? doin the 2 runs to the other batts would be easy since all three batts would be in the trunk. do u mean 2 runs per each new batt, or one each? u know where i can get some 1/0 wire? and, i think from the autotek thats 4000rms at about 14v, which i will only get about 13v so i will barely get over 3000rms from it i think? but do u have any amp suggesstions? wat do u think bout the audioque 3500d? it gets 3500rms at 14.4v.. so at around 13v idk how much itd get bet probably less than the autotek. and, how does a new starter help? i never thought bout doin that. u know of any good ho alt brands? Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
bmwkingaudio Posted August 26, 2008 Author Report Posted August 26, 2008 also, u think i should replace my current batt wit like a powermaster 3100d or sumtin? Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
bmwkingaudio Posted August 26, 2008 Author Report Posted August 26, 2008 can someone remind me wat the 3 steps of the big 3 is again? and do i hav to do it per each of my batts or for just my main batt. and then do runs from the main to my 2 others Ride: 2001 BMW325ci Headunit: Alpine ida-x305 High/mid: stock harmon/kardon everything: 6 tweets, 1 set of 6.5" and 1 set of 6x9, 500rms total Sub: (1) 15" DC Audio Level 5 D2 ohm Amp for sub: MTX 4001d Box: custom built 3.5 cuft ported Power: 220amp alt from ohio gen, 2 kinetik 2400s in back (Armoredhaulin @ May 29 2009, 08:34 AM) Why waste your time with this tool? His system sucks, that's all there really is to it. My toilet puts out more low end and flex than that thing!
