jcm1689 Posted August 9, 2008 Report Posted August 9, 2008 If i were to use an 8v line driver would it mattter if the the pre out voltage on my deck was low like 2 volts or would it be better to have 4 or 5 volt pre- outs? i ask because i am looking to buy a deck for my durango.(which will eventually have a pretty large system) i already have a line driver and im not big on fancy decks. i like the mid-line decks that are easy to use and dont have many features since i do all my tunning off my 3 sixty.2? so should i spend an extra 100 bucks just to get 5v preouts vs. 2v? R.I.P. KOOLAID KING --- Thomas Johnson 04/02/1986 - 06/09/07 THUNDER CAR AUDIO Chris's 91 hatch - 2 18" BTL's, 2 T40001BD's, 153+ dbs Chris's 2005 BMW 525i Chris's 2002 Ford Ranger 2004 Silverado Blow Through 1999 Silverado - 4 15" SSD's Fiberglass Top Infinity G20 *RIP KOOLAID KING* Dodge Stratus - 2 12" Power HX2's, Fiberglass Baffle
DUBIE Posted August 10, 2008 Report Posted August 10, 2008 If i were to use an 8v line driver would it mattter if the the pre out voltage on my deck was low like 2 volts or would it be better to have 4 or 5 volt pre- outs?i ask because i am looking to buy a deck for my durango.(which will eventually have a pretty large system) i already have a line driver and im not big on fancy decks. i like the mid-line decks that are easy to use and dont have many features since i do all my tunning off my 3 sixty.2? so should i spend an extra 100 bucks just to get 5v preouts vs. 2v? always go with a higher voltage on HU's...its better and it will sound even better!. ..go like about 4 or higher..
Forceww Posted August 10, 2008 Report Posted August 10, 2008 It does not matter really. If you have a lower preout voltage on your headunit then your gain on your amp will be up a little more and same if your preouts are a higher voltage your gain on your amp can be turned down more to achieve the same output **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari
jcm1689 Posted August 10, 2008 Author Report Posted August 10, 2008 always go with a higher voltage on HU's...its better and it will sound even better!. ..go like about 4 or higher.. It does not matter really. If you have a lower preout voltage on your headunit then your gain on your amp will be up a little more and same if your preouts are a higher voltage your gain on your amp can be turned down more to achieve the same output even with the 5v preouts of the 3sixty.2 and a 8v line driver? R.I.P. KOOLAID KING --- Thomas Johnson 04/02/1986 - 06/09/07 THUNDER CAR AUDIO Chris's 91 hatch - 2 18" BTL's, 2 T40001BD's, 153+ dbs Chris's 2005 BMW 525i Chris's 2002 Ford Ranger 2004 Silverado Blow Through 1999 Silverado - 4 15" SSD's Fiberglass Top Infinity G20 *RIP KOOLAID KING* Dodge Stratus - 2 12" Power HX2's, Fiberglass Baffle
PaulO2288 Posted August 11, 2008 Report Posted August 11, 2008 I love LineDrivers/EQ's they help make produce cleaner sound by far and they have great control. I would always go with higher voltage, the higher you can get the better, less work for the amps, and mine remain cooler.
ptcary Posted August 12, 2008 Report Posted August 12, 2008 I think if you have an 8v preout line driver or 3.Sixty from RF, then the preout voltage from your head unit would not matter. I chose a 5v preout head unit from Eclipse, because my amplifiers have an input range up to 5v. PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
