Clocksta Posted August 10, 2008 Report Posted August 10, 2008 i'm trying to find some cheap (and i mean CHEAP) subs off the net for a budget/first system. i'm thinking like...30-50$ per sub 10's or 12's. i want to put as many as i can in my trunk but not to sure of how many i would be able to fit. but i want to try it. i'm going to be running sealed with each sub in seperate compartments of the box so i can still run something while working on the cash for more to come. any suggestion are appreciated. and these are what i was thinking about http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18394 or something along those lines
tacomabanga1986 Posted August 10, 2008 Report Posted August 10, 2008 i would do these, i had a set of the 12'' of these http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=13515 and they wanged pritty good, acually really good well worth the $50 each i gave for them and im thinkin either multi 10's or 12's and u'll be slumpin, or u can try other brands like these, http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=17721 i might just buy me a set of these to play with, but alot of those ina good sealed box would slump pritty good maby even 12's http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=17723 will work and look clean, im thinkin either 4 12's ported or 6 12's sealed would be a killer setup if u got the power for em will be a good streat beater, what kinda car u got? here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Clocksta Posted August 10, 2008 Author Report Posted August 10, 2008 03 alero, not the biggest trunk around = /
honda Posted August 10, 2008 Report Posted August 10, 2008 are you trying to do this? name="allowFullScreen" value="true"></param><embed src=" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><embed src=" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> name="allowFullScreen" value="true"></param><embed src=" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><embed src=" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">Do a dozen of these: http://www.sonicelectronix.com/item_8632_P...TS-W1007D4.html My Soundz: '06 ACCoRD Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU) CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ TWO Diamond D6 12" DVC 4ohm Coming soon upgrades: Batts dynamat trunk kit
Clocksta Posted August 10, 2008 Author Report Posted August 10, 2008 if by "this" you mean multiple low lvl subs in my trunk sealed up, then yes
Clocksta Posted August 11, 2008 Author Report Posted August 11, 2008 Bump- still dont know whats best to go with
L0WT0N3Z Posted August 12, 2008 Report Posted August 12, 2008 you should check out maxxsonics, specifically hifonics or crunch. You can get hifonics hfi12 for 35$ a piece. or some crunch gp10s for 60$ a piece. L0WT0N3Z Audio
