Posted (edited)
ok so i just started 1 other small project my buddies truck he has a 1999 silverado.. its a crew or quad cab it only has the 3rd door... but ne ways he is wanting to keep his backseat we put a 3" lift on it so we can get a big box underneath it .... im putting 2 -12" jbl P series subs
http://manuals.harman.com/JBL/CAR/Boxes%20...4rev3_27_06.pdf ----- link to the box spec.
im am wondering if a vented box would sound good in there considering the box goes up and over the drive tunnel?? and if i could do the vent in the middle where it goes over and subs on each side facen your feet....
so my big ? is has any one seen or heard this... if so do you think a seald or vented would be better for his application??
sealed=1.00 cube
vented=1.75 cube
thanks guys ill get som specs and see if any one can help with the design
Edited by trulywickedcustoms
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
come on guys i need to be able to start his box sumtime next week any suggestions???
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Posted (edited)
Okay I did a little reading on the sealed box and the woofer, and I think that there graphs is a little off. Why?
Look here: http://www.carstereo.com/help/Articles.cfm?id=29 and read on the Qtc. They say it's best to get a Qtc of .707, which is somewhat similar to how the music was originally recorded.
So I tried out this equation for a seald box based on your woofer and volume requirement:
http://www.carstereo.com/help/Articles.cfm?id=30
From this:
Qts .54
Vas 1.932ft cubed
Fs 27hz
Vb 1 ft cubed
And got this:
Qtc: .9246
Fc=46.23hz
F3= 37.77hz
Edited by quakecitystudio
Bass Music Producer • Photographer • Graphic Designer
Deep Sector Boom...
Posted (edited)
In comparison I decided to try out the RE Audio RE Series 8" woofer:
Qts .34
Vas .957
Fs 22.8
Vb 1
and got this:
Qtc .4756
Fc 31.9hz
F3 53.18hz
Deep Sector Boom...
Posted (edited)
I noticed my own flaw with Vas I was using liters and not ft cubed, and went back and corrected everything.
Are you wanting a sketch of the enclosure? What would your dimensions be? L W H Depth and the curve radius over the drive axle.
Deep Sector Boom...
thanks for helping im tryn to get him to email me the dem. b/c he wrks all week out of state.....
but ill get them asap and yeah i would like a roughd sketch with demen thrown in to help ... if thats not to much trouble...
thanks man
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
i think im kinda wanting somthing like this ... or sealed or with the boxes split with a port individually??
just sum thoughts
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
come on guys im supposed to start this build this weekend .. ill have demn 2night
do yall even think the idea is good?? and should i do seperate boxes or even sealed??
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
looks good but you are definitely going to have to raise the seat up
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
It is an ext cab not a quad cab.
Do the port out the side both woofers on the opposite side.
