O I was already planning on doing that.... im looking at like a 1500 Rms one. But thanks for the response. :friends:
I would recommend a Sundown 1500 or Rockford T10001bd or even a Rockford T15001
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Whats size wire would I need from the Amp to the subs?
If you get some good 1/0 wire from the start you won't have to spend the extra money to upgrade later...
I do box designs.
well hopefully when you buy this 1500rms amp you set it properly or kiss those Sony subs good bye. i'm not doubting your skills are anything but be careful on cheap subs man. like my man said ............... get 1/0 for the power and ground wire. you can always run each to it's own distribution block and run smaller gauge power and ground wire such as 4ga or 8ga to the amp(s). good luck
Edited by dmanson
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
