Independent Charging System.
hey everone how can i have my two 300 amp iraggi alternators charge ONLY the batterys for the amp and not the battery for the car as well
is it as simple as just running power and ground wires from the alternators to the batterys? im gonna have two groups of three. (three for each amp ) of course they will be fused. what else will i need
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
What type car? Our stand alone module can do all your needs if you run GM/Ford alts and get you more voltage as well.
Let us know, MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
if you just want that alternator to charge the audio batteries alone, i would think you just run the power wires straight to the audio batteries.
Let us know, MLA
its a gmc safari 1995 . i will be using iraggi alternators
im looking to stick with 12 volt system. but i would ike a seperate charging system.
missing link audio ill probably go with your products. do you guys have any decals that can go on my comp vehical?
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
You can run a pro duel volt module for comps. Our 15v module is for your 12v system and is the only way to fully charge a battery. You would need our stand alone unit for the seperate alts. GM units are plug and play very easy install. We have some stickers white and silver courtesy of Mr derrick.
Krannyman92 Posted Today, 11:04 AM
Here is why we suggest a module. We had a customer buy a duel module and ran them seperate like you are saying. Example) The voltage to his facory alt was 15v (fine) He wired the second alt direct to the back batteries and it jumped to 18v. When he tied them back together they both ran at 15v. Your cars charging system uses sensing wires to control the voltage and when you seperate the alts it no longer has a reference point. Our (stand alone) module has this function built into it, and can then run on its own at 15,18,24volts it wouldn't matter nor affect your cars electrical.
MLA
missinglinkaudio
so what will i need for my application i will have two alternators two amps and six batterys total. (three batts per alternator )
the alternators will be irragi 300 amp so give me a quote for what i need shoot me a pm
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
