Is it possible to tune a computer woofer lower?
i have the logitech g51 5.1 surround sound shitters - and figured its a box... with a port... why couldnt it be tuned different? anyone know how? i want it lower to like 40 hz or something ... so i know what would pound in my car instead of hearing a completely differnt sound.
you ain't been bizzy til you've been wit jizzy.
Vehicle:: 2005 Saturn Ion
Headunit:: Jensen 9312HD
Speakers:: RE SE Coaxials
Subwoofer(s):: (2) 15" RE SEs
Amplifier(s):: Audiopipe AP1500.1D
Audiopipe AP1504
Enclosure:: Sealed
Wire: KNU KONCEPTZ 1/0
Battery:: Kinetik HC600
sorry i wanted to get this sent to my phone-- and i dont know how otherwise withouht doing another post
Audiopipe AP1504
Enclosure:: Sealed
build a box with the tuning you want...
besides that... i knew that lol... but like changing the port size or anything? i dont know how ports work exactly... would i need to make the port larger or smaller to make it lower?
Audiopipe AP1504
Enclosure:: Sealed
Tuning lower takes more port sq. in.
EDIT: Actually a longer port of the same diameter because you could have more sq. in with a bigger diameter and have higher tuning. Try getting some different length PVC pipes the same diameter as the port and seeing if putting that in addition to the port there gives you the desired sound. Although with the small size of the sub box, you probably won't get your desired tuning.
Edited by Btrash
according to the port calculator... (which is my new favorite toy) i would a 1inch in diameter port and keep the same length to get to 40hz ... which doesnt sound right
edit- the port now is 3inches in diameter.. so i would be taking away sq in.
Edited by jizzybizzy
Audiopipe AP1504
Enclosure:: Sealed
On round ports, the smaller the tube the shorter the port to tune lower, the bigger the tube the longer to get lower tuning.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
