Krice420 Posted August 23, 2008 Report Posted August 23, 2008 i am drawing up my port dimensions and im not quite sure on which setting to use. i want my port to be like this __ |__ with the walls of my port going flush to the back of the baffle. do i need to use two flush or 1 flush because this picture it has is kinda misleading. also the length it gives me i have to subtract the baffle from that as well correct? 2 18'' fi btls fully loaded 2 sundown saz 3000d 1 iraggi 200 amp alt 3 powermaster 3100d series batts 11.75 cuft wall after displacement tuned to 31.08 hz
audioaddiction863 Posted August 23, 2008 Report Posted August 23, 2008 one flush and add the length of your baffle to the length of the port. if it tells you to make the port 10 in long and you have a 3/4 in baffle your port needs to be 9 1/4 inches long. Its all about the Install !!!! http://www.youtube.com/user/audioaddiction863 Bass Race Florida State Champ runner up 139.9 2008 Bass Boxing Florida State Champ runner up Middleweight 2008
Krice420 Posted August 24, 2008 Author Report Posted August 24, 2008 wait you sure its not 2 flush because that pic i did didnt line up right. both sides will be flush to the baffle. the baffle is cut to dimensions already in baffle. 2 18'' fi btls fully loaded 2 sundown saz 3000d 1 iraggi 200 amp alt 3 powermaster 3100d series batts 11.75 cuft wall after displacement tuned to 31.08 hz
