Since it tells me that....
I was wondering if I could take off a fan from my old pc and put it on this pc......
It's possible to my knowledge, but where do I connect it?
yessir look for a cable like
most computers will have an extra power pin sprouting off one of the cables for future add ons so just look for one of those if not you will have to buy a splitter
Guest SyKo13
Well after running this test.....
That fire trash thing doesn't look so good lol, yet I have no clue what "Remote" is
"First of all, you have to identify which temperature sensor is which. SpeedFan strictly adheres to available datasheets for each sensor chip. Please remember that hardware monitors are chips that do have some pins (small connectors) which should be connected to some additional hardware (temperature probes, thermistors or thermocouples) in order to be able to read temperatures. Only a few hardware monitor chips do label their connectors with "CPU", "System" and the like. Most of them use labels like "Temp1", "Local" or "Remote". The hardware manufacturers connect available pins to different temperature sensors basically according to the physical placement of components on the motherboard. This means that the same chip, an ITE IT8712F, for example, might be connected to a sensor diode measuring CPU temperature on Temp2 and, on a different hardware, it might be connected on Temp1. If you have a "Local" sensor and a "Remote" labeled one, this usually means that "Local" is the temperature of the monitor chip itself and "Remote" is the temperature read from a "remote" probe.
When you have properly identified which temperature sensor is which, try to lower the speed of each fan and look at reported speed and temperatures. If you do not allow SpeedFan to change any fan speed and set all the speeds too low, then SpeedFan won't be able to avoid overheating. "
ok fine you pineapple flavored cunt
