don't forget safety!!!! i wasn't thinkin when i was lowering my toy and took the bolt outta the middle clamp and pow!! the meaning of SPRING became very clear as it pinned my hand to the gound. luckily it caught the meat of my thumb off-center of the spring cause otherwise it woulda broke my hand. the guys that sold me the lowering blocks didn't tell me to prop the spring i don't hurt myself!
i agree with footlong lower the front ive got a 2001 blazer with 12 16v batterys and a wall that i drive daily. i lowered the front 2" and tha back 3" it still saggs but i think it looks cool. maby it saggin isnt such a bad thing. bcause it looks like its taking off when its sitting still.......
158.1 db at 50 hz best life time score
154.1 street beat
3 TRF 12's
3 fusion fca 4000d's "need some cooling ideas" lol
12 hc 16's
suedo wall
more to come very soon
  • 1 month later...
  • 3 months later...
New shackles will be the easiest way.
in the front or back? cause if this new install makes it lower too much i'm going to put leafspring helpers in back and that will give it a 3inch lift and so i wanna do like 2 inches in the front then so it don't look like my ass is in the air. lol
Bills
KwB
Team DC Audio Midwest captain
If its 4x4 id leave the front alone. You put the shackles in the rear. its how the leaf springs attach to the frame in the rear portion of the spring. You can get some for 1.5 lift. will run about 50 bucks. imo easier to swap than adding leaves etc.
Also in stock setup you cant use blocks to raise the rear. the axle is over the leaf, blocks only lower. To raise with blocks the axle would have to be swapped to under the leaf.
Also you could just the front torsion bars down to level it out, that would be free and only requires turning bolts.
2015 Chevy Sonic
CTX65cs - Image Dynamics 6.5" front
CTX65 - Image Dynamics 6.5" rear
Rockford Fosgate 3Sixty.3
Rockford Fosgate PBR300x4
Sundown SAE-600D
Sundown SD3-10
Weird my box weighs around 150lbs.....subs another 50 or so....amps another 50 or so and batteries another 50...then about 30lbs or more in 1/0.....
So over 300+ pounds and mine only sags maybe .5 to 1".....maybe you need new shocks or springs altogether?
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
  • Who's Online   1 Member, 0 Anonymous, 853 Guests (See full list)
