i dont know if you can tell anything from these pics put the is the harness i got.
the harness that plugs into my facotry harness
then my after market harness goes to this from the factory harness then threw this it goes to my headunit.
here the whole setup if you notice the yellow, red. and black were unplugged for testing.
I dont think you would you already have the gmrc-03 the only reason for that harness is if you want to bypass the amp and run factory or aftermarket off the deck. but with a 4 channel you have already taken care of that. If you need wire colors for anything let me know i have acsess to a few diffrent resources.
and the guy who made the original post please dont use a test light even if it says they are computer safe it has been proven they are not. Get a good dmm and be on your way.
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
i am pretty sure that haness is supose to generate an acc lead. If not you can put in a relay or see if u can get a new one
sub:2 DC lv4 12
ill give you an update tommorow. i put the fuse and the headunit back in. if it dont start tommorow after 2 days of sitting witch ussally drains the battery all the way down i will do some more testing.
let me know i can tell you a way to check current draw with your dmm if u dont figure anything out
sub:2 DC lv4 12
  • Who's Online   0 Members, 0 Anonymous, 469 Guests (See full list)
