So My Friends System Is Having Problems.
The amp cuts into protect when it gets to a certain level (no clue why i checked the voltage and its 14 volts and only drops to 13) hes only running a 75.2 jbl amp on 2 old pioneer subs and to be honest its pretty good. I was thinking it could be the ground?? He said the ground was shitty when the guy installed it but i have no clue what it could be. Im still a novice at this kind of stuff (i install etc) but i have no idea why it could be cutting into protect. any tips?
impedance maybe?
ground as stated?
I recall taking out one of the subwoofers because it wasnt playing (loose wire) and it said 4 ohms on the back and it had the weird terminals nothing like my kickers. And it said 4 ohms and i believe both subs are wired in series?? I have no clue with those weird terminals
pic of amp and subs if u will plz, need somethin to see to kno what were thinkin of, could be a # of things, ohm load to low, bad ground, overheatin, subs shortin out, can u take pics of the system so we can see more of what ur talkin bout?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
can you explain what subs shortin out means?
subs shorting out? probably means that the + and - speaker wire touched or something. check the ground, make sure its on a full metal bar or something, and all the paint is ground off under it and a little bit around. you can have the subs wired to 2 ohms or 8 ohms, unless its a dual 4, then i think its 1 ohm and 4 ohms.
subs arent shorting out then. Its most likely the ground, if not i guess ill check the independence
  • Who's Online   0 Members, 0 Anonymous, 2396 Guests (See full list)
