Guest MegaloManiac
well my router has a built in 128bit encryption. But i believe you can reprogram the routers that dont have them in a setting. if you can find a manual to your router that should help you a lot. You have to type some url in your adress bar and it will take you to the router settings and there should be a setting to where u can enable an encrytion and it should give you a code for it
ok i found the router number... its like... well i can't say... then what ?
  • Who's Online   1 Member, 0 Anonymous, 1665 Guests (See full list)
