Does any1 know what the amp will put out at 4ohm on 1 chan??
HK802SX
HK802SX
4400W 2 Channel High Current Amplifier
Specifications -
2 x 500W RMS @ 4-Ohm Stereo
2 x 800W RMS @ 2-Ohm Stereo
2 x 1400W RMS @ 1-Ohm Stereo
2 x 2200W RMS @ 0.5-Ohm Stereo
1 x 4400W RMS @ 1-Ohm Bridged
Dimentions (H x W x L)
2.7" x 12.4" x 10.6"
__________________
Wait ignor that read the specs wrong 500 x 2 500 watts per channel bridge it to get 1000- 1600 brain fart
Edited by Team Bassick (ALPINE)
and to get that 4400rms you'll have to run the amp at 17 volts potna. i got the HK602SX and called the MA Audio Headquarters (talk to Dan - technical support). so if you ain't putting 17 volts on it then at 1 ohm you'll probably see 3000rms
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 807 Guests (See full list)
