Driver side mid "thumping"
Guest MegaloManiac
Today I spent the day beating my head. I tore apart my whole car and reinstalled all the wiring for my frontstage. I was getting an alternator whine and my driver side AA kept thumping. Well I redid the wiring. I chaged the speaker wire. needed to be replaced not enough shielding, I was using 18awg stinger remote wire. I upped to some radioshack 16awg speaker cnductor wire . I got rid of the alt whine, hopefully, I only drove around for a couple of blocks. ill know for sure when I ride on the highway. But for some reason my driver side keeps "thumping". Any ideas why? its annoying as hell. its thumping even with at low volume. I thought the speaker wire would solve the problem. This replaced it with another AA that I got from Ray, thinkin the otherone was blown. All input appreciated.
Guest MegaloManiac
every thing is amped and crossed over. amp is an Avionixx 440.4. I'm running active. i'll trying switching it. do you mean switch the signal(rca) or switched the speaker wires with each other?
I would say RCA pinched, or to close to something its not supposed to be, rca pulled on to hard, loose solder connection to rca plug on amp, or deck, rca half hangin off deck rca.. Ive ran in to that many times, but usually both sides together, not 1 side over another
Guest MegaloManiac
no its not the rcas. I did replace them that day with knukonceptz and Raptor. I haven't tried ur suggestion yet audioaddiction. i'll do it this weekend. but it seems like something is interfioring with it. whenever I had my sub amp on it made it worst. but now I don't have a sub amp. but  we'll see how it goes.
Guest MegaloManiac
ok I'm driving right now on hghway and it  stopped whining but the thumping is there hardcore. ill try switching the speaker wire sides tomarro.
;) i dont get the question what do you mean thumping describe it better please
- ROE Refs- Majorpayne, Roe, Ceestaypropa, bandcamp, Dumple91, pimpedout97x, Corey anderson, JEXTEL- CA Refs - rtillaree, Rich00 Seismic Disturbance C.C Riverview FL.
Guest MegaloManiac
I described it in an Onamonapia form. when I mean thumping I mean thumping. just random thumps happening.
