Sonic took the one amp back... and no after some talking they will take both back.... and I am left with nearly 500 sonic bucks to use.
So new choices
1. http://www.sonicelectronix.com/item_4238.html
Hifonics herc. wired at .35 ohms....
2.http://www.sonicelectronix.com/item_5647.html
Mtx TA81001 at .35 ohm
3. http://www.sonicelectronix.com/item_3660.html
Alphasonik PMA12000da at either .35 ohm or 1.4
4.http://www.sonicelectronix.com/item_7151.html
power acostic sl3400d at either .35 ohm or 1.4
5. http://www.sonicelectronix.com/item_5382.html#
What i probley should of gotten.
6. anything else you guys suggest from sonicE
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
I say save up and get the Colossus
2003 Chevy Blazer 4drPioneer AVIC-D3Memphis 9 volt line driverRE Audio XXX compsPower Acoustik NB-4 tweeters (x4 on dash)Crescendo 1000c42 Alpine Type R 15s (2 more and new box coming soon) Hifonics XXII ColossusIraggi 300A AltKinetik Hc800 up front and 2 2400s in the backKicker Hyperflex 1/0 and 4 gaugeDDM Tuning H.I.Ds35w 10,000k in projector low beams55w 12,000k high beams
So new choices
Hifonics herc. wired at .35 ohms.... not gonna like .35 at all
Mtx TA81001 at .35 ohm wont run under 1ohm
Alphasonik PMA12000da at either .35 ohm or 1.4 wont run at .35 so look at 1.4
power acostic sl3400d at either .35 ohm or 1.4  again not gonna work at .35
so it sounds like colossus at 1.4 ohms
my question is this, Whys everyone getting dual .7 coils, it just makes it a pain in the ass to find an amp.
a colossus is rated at 1ohm times 2 or 2ohm, it may work out for you but i ran one of mine at 1ohm bridged and smoked it.
i'll run it at 1.4 bridged...
heck my alpines were 3.7 or 1.6
i'd get the herc... knowing they are .35 ohm stable.. :weight_lift:
they are not, they will send a clipped signal, they work but you wont get a clean signal, ask lil kb
if it fries be ready for the I told you so
i thought he smoked his cause of him not setting the gains right...
  • Who's Online   0 Members, 0 Anonymous, 7157 Guests (See full list)
