Box Help
marquettefan247
do you think u can get me some plans?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I need specs on the subs then I can help you. Read my post above^^
2 15 inch ma audio 1500 xl subs
http://www.sonicelectronix.com/item_2761_MA+Audio+MA1500XL.html
with a 1600watt ma audio amp
make my shit bump pimp
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Well acording to amatt's port calc make your box 18Hx35W31D with a port 6.5" wide and 16.75" deep. That doesn't leave you ANY room for bracing. The box is 8.03ft^3 tuned to 35.03 Hz after displacement of subs. Is there any way to go any bigger? And I suck at SketchUp so I can't draw you a diagram. But I can provide you with a cut list.
If I could make my trunk bigger I would. I use my backseat so Idk. is that oin a slant? i can face it another way
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
will that help i want that kind of box he has some specks on page 3
or
like that shape but a port
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Do you care if the port is in the middle or on the side?
dont care
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
My design has no slant. If your not removing your backseat, then facing the rear of the trunk may be louder. The only way to find out which way is loudest is to try multiple designs and see which one sounds loudest to you. Are you building this box or is someone else?
well I will be there when it is being built so yes
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 438 Guests (See full list)
