Box Help
marquettefan247
can u do both?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
Yea: Dimensions are 18Hx35WX31D with port 6.25" wide and a 16-7/8" long port.
Cut List:
Top/Bottom 35x31
Left(port side) 30.25x16.5
Right 29.5x16.5
Front 28x16.5
Back 35x16.5
Port L1 16-7/8x16.5
Add some 2x4 bracing from top to bottom between the subs(middle of box) on the front and back(inside), then put 1 2x4 from front to back on top and bottom and screw them to the other 2x4s. If that doesn't make sense I'll try to paint a picture(bad pun LOL)
all makes sense but the bracing please paint me a pic lol
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I knew something was wrong. I thought you had 12s which would have been fine. You may want to try sealed first. It will punch harder and sound cleaner than a ported box. If you still want ported your going to need a bigger box, mainly wider. Is there any way to get 41" wide?? If so I can make ported work.
ok i cnat do 41 inches wide it wont fit how bout more depth that guy in the youtube link i posted did it
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
i dont know this second i will check bfore school tommorow but i think 40-50 inches ill post before 7:00 central time an be back on at 9:10-10:04 central time then randomly till 2:45 central time k
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 438 Guests (See full list)
