marquettefan247 Posted September 17, 2008 Author Report Posted September 17, 2008 my trunk has 40inch depth and then i can only do 36 wide cause its my whole trunk. I can face my subs upward so my whole trunk is used. The widest i can go is 40 inches ill get more measurements later. 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
marquettefan247 Posted September 17, 2008 Author Report Posted September 17, 2008 bump 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
marquettefan247 Posted September 17, 2008 Author Report Posted September 17, 2008 is every one dead or what 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
duct_tape123 Posted September 17, 2008 Report Posted September 17, 2008 I don't understand, you information is inconsistent. What is the max width, and depth. I can make subs up port wherever work, but I need consistent info.
marquettefan247 Posted September 18, 2008 Author Report Posted September 18, 2008 ok here is a drawing of my trunk 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
marquettefan247 Posted September 18, 2008 Author Report Posted September 18, 2008 do magic ductape 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
duct_tape123 Posted September 18, 2008 Report Posted September 18, 2008 With your dimensions can you fit the box in the trunk? And which way is the front? And will subs up port forward work for you?
marquettefan247 Posted September 18, 2008 Author Report Posted September 18, 2008 which plans u said to disregard the plans the origional box is 35 wide 16 high 22 deep and an angle of 17. if u can tell me iff i should face dem diff ways 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
marquettefan247 Posted September 18, 2008 Author Report Posted September 18, 2008 BUMP 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
