Help No Sound!
+ZER0Hz+
I know its prolly been here already, but I dont have time to search through the site.
My system this morning was fine, I went and picked up my friend, and in her neighborhood, i turn off the amp with a switch hooked to the amp turn on lead. After I picked her up, I went and turned the switch on again. There was no bass.
I just got a break from school, so I went to the ATM and looked at the amp and everything
its a kenwood 8--somthing D 550 rms @2
Subs = Kenwood KFC-W3011's (2)
The power light is on, but theres no sound coming out. I looked at the fuse for possible cause, and the fuse is fine. Im at a loss as to what may be going on, before I turned off the switch, the bass was very low, so I dont know what could've been the cause, could my subs be blown?
2009 VW Rabbit 2-Door:
Pioneer AVH-X1600DVD
Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm)
NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box
Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets
Owner/Founder of RT Photography
Canon Traitor who moved to Fujifilm
u try to see if ur rcas is fine? and piddle with the gains to see if that might be it or if somethin is set different on ur headunit, ied try there to, i normally turn off my subs on my headunit with the sub control i dont like useing a switch but to each his own, i would try ur rcas to see what shape there in it might be those, or so or maby amp goin bad or subs im not to sure
I'd check rca's and speaker wires if it's something that happened between getting in and out of the vehicle.
Are your wires/rca's/any connections exposed anywhere where they could have gotten moved or pulled?
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
im going thorough the car's entire electrical today, so ill post what i find...
its probably a loose connection from the wreck... I should have mentioned it was in a wreck about a month ago
blargh....
batt == normal voltage
voltage over fuse == batt voltage
voltage over cap..... 35 mA :\ (over pos / neg both car on and off)
amp = not even turning on anymore
Tomorrow, getting new fuse block, while there, ill see what i can do to bypass my cap with minimal work
How would i test the turn on lead? (where would i put pos / neg?)
Oh and I bypassed the switch on the turn on lead.
BLAGH!
edit: now where did i put that "fuck that" thread....
get like 3 inches of wire and touch the +12v bolt to the REM bolt on your amp, it should click right on, if not, bad amp/ground/power
if you have a multimeter and checked + to ground and + to- bolts and got consistant readings, and it doesnt turn on, time for a new amp
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
i suspect that it has something to do with the wiring, because the fuse on the amp wasnt blown
blah no bass = fail, epic
  • Who's Online   0 Members, 0 Anonymous, 1282 Guests (See full list)
