+ZER0Hz+ Posted September 15, 2008 Report Posted September 15, 2008 I know its prolly been here already, but I dont have time to search through the site. My system this morning was fine, I went and picked up my friend, and in her neighborhood, i turn off the amp with a switch hooked to the amp turn on lead. After I picked her up, I went and turned the switch on again. There was no bass. I just got a break from school, so I went to the ATM and looked at the amp and everything its a kenwood 8--somthing D 550 rms @2 Subs = Kenwood KFC-W3011's (2) The power light is on, but theres no sound coming out. I looked at the fuse for possible cause, and the fuse is fine. Im at a loss as to what may be going on, before I turned off the switch, the bass was very low, so I dont know what could've been the cause, could my subs be blown? 2009 VW Rabbit 2-Door: Pioneer AVH-X1600DVD Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm) NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets Owner/Founder of RT Photography Canon Traitor who moved to Fujifilm
tacomabanga1986 Posted September 16, 2008 Report Posted September 16, 2008 u try to see if ur rcas is fine? and piddle with the gains to see if that might be it or if somethin is set different on ur headunit, ied try there to, i normally turn off my subs on my headunit with the sub control i dont like useing a switch but to each his own, i would try ur rcas to see what shape there in it might be those, or so or maby amp goin bad or subs im not to sure here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
The Performer Posted September 16, 2008 Report Posted September 16, 2008 I'd check rca's and speaker wires if it's something that happened between getting in and out of the vehicle. Are your wires/rca's/any connections exposed anywhere where they could have gotten moved or pulled? CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner
+ZER0Hz+ Posted September 17, 2008 Author Report Posted September 17, 2008 im going thorough the car's entire electrical today, so ill post what i find... its probably a loose connection from the wreck... I should have mentioned it was in a wreck about a month ago 2009 VW Rabbit 2-Door: Pioneer AVH-X1600DVD Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm) NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets Owner/Founder of RT Photography Canon Traitor who moved to Fujifilm
+ZER0Hz+ Posted September 17, 2008 Author Report Posted September 17, 2008 blargh.... batt == normal voltage voltage over fuse == batt voltage voltage over cap..... 35 mA :\ (over pos / neg both car on and off) amp = not even turning on anymore Tomorrow, getting new fuse block, while there, ill see what i can do to bypass my cap with minimal work How would i test the turn on lead? (where would i put pos / neg?) Oh and I bypassed the switch on the turn on lead. BLAGH! edit: now where did i put that "fuck that" thread.... 2009 VW Rabbit 2-Door: Pioneer AVH-X1600DVD Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm) NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets Owner/Founder of RT Photography Canon Traitor who moved to Fujifilm
raytard Posted September 17, 2008 Report Posted September 17, 2008 get like 3 inches of wire and touch the +12v bolt to the REM bolt on your amp, it should click right on, if not, bad amp/ground/power if you have a multimeter and checked + to ground and + to- bolts and got consistant readings, and it doesnt turn on, time for a new amp Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
+ZER0Hz+ Posted September 18, 2008 Author Report Posted September 18, 2008 i suspect that it has something to do with the wiring, because the fuse on the amp wasnt blown blah no bass = fail, epic 2009 VW Rabbit 2-Door: Pioneer AVH-X1600DVD Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm) NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets Owner/Founder of RT Photography Canon Traitor who moved to Fujifilm
