truck_buster23 Posted September 16, 2008 Report Posted September 16, 2008 Could anyone tell me what this box is tuned too? 3/4" MDF Volume: 2.90 cu. ft. per chamber Depth: 20 1/4" Height: 16 1/4" Mounting Depth: 17" Port Length: 26 1/2" Width: 40 1/4" Port Width: 1 1/4" Port Height: 14 3/4" Eclipse Hifonics Alpine Kinetik Optima Excessive Amperage alt
truck_buster23 Posted September 17, 2008 Author Report Posted September 17, 2008 I have a few bucks on my paypal if someone could help with this please. Eclipse Hifonics Alpine Kinetik Optima Excessive Amperage alt
duct_tape123 Posted September 17, 2008 Report Posted September 17, 2008 If you want, paypal [email protected]. I came up with 5.23 ft^3 @ 17.5Hz
truck_buster23 Posted September 17, 2008 Author Report Posted September 17, 2008 If you want, paypal [email protected]. I came up with 17.5Hz Thanks for the repy well I forgot to mention that it has a divider down the middle and there are 2 ports. here is the box maybe that will help a little better 17.5 cant be right. I will send paypal in a few. http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3525 Eclipse Hifonics Alpine Kinetik Optima Excessive Amperage alt
duct_tape123 Posted September 17, 2008 Report Posted September 17, 2008 I get 2.0ft^3 @ 27.9 Hz per side
truck_buster23 Posted September 17, 2008 Author Report Posted September 17, 2008 I get 2.0ft^3 @ 27.9 Hz per side Thanks I want to build a box just like this so I know it is built sealed up with no leaks and tight. paypal sent. Eclipse Hifonics Alpine Kinetik Optima Excessive Amperage alt
duct_tape123 Posted September 17, 2008 Report Posted September 17, 2008 Might try this one. Just guessing I get 4.7ft^3 @ 34Hz If you want, just give me your info and I can design a box for you. And thanks for the $!!!
truck_buster23 Posted September 17, 2008 Author Report Posted September 17, 2008 Might try this one. Just guessing I get 4.7ft^3 @ 34HzIf you want, just give me your info and I can design a box for you. And thanks for the $!!! Well the box can only be the size of that ground shaker that is the max I would have to take the trim out of my trunk to squeeze it in. As for the subs I will use they will be probably type r 15's. or other 15's that need around the same cu ft. Eclipse Hifonics Alpine Kinetik Optima Excessive Amperage alt
