bigarsenal Posted January 6, 2007 Report Posted January 6, 2007 ima little lost can i take the power wire from the front battery pos post and put it on the pos of second battery post then take a wire from the second battery neg post straight into the amp sorry for asking just want learn ;D Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Guest SyKo13 Posted January 6, 2007 Report Posted January 6, 2007 Why you wanna ground onto the amp for???? Kinda confusing how you put it lol
thacarter546 Posted January 6, 2007 Report Posted January 6, 2007 take the wire that is conected to the amp + terminal right now and nnect it to the batt in the back, then ground the - terminal of the batt in the back, then run a wire from the + on the batt in the back to the + in on the amp, and one from the - on the back batt to the - in terminal on the amp sounds like thats what you were doing
dmanson Posted January 8, 2007 Report Posted January 8, 2007 take the wire that is conected to the amp + terminal right now and nnect it to the batt in the back, then ground the - terminal of the batt in the back, then run a wire from the + on the batt in the back to the + in on the amp, and one from the - on the back batt to the - in terminal on the amp sounds like thats what you were doing you should be find doing that broham. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
