Ive done that once about 4 years ago, DVC 4ohm subs, 2 mono blocks, just marked right/left on the terminals of the subs, marked Right /left on the amps, wired 3 coils to one amp, 3 coils to the other amp
done
just gotta tune the amps right, or you will lose bass, or screw up the subs
amps can be the same model but its risky unless they are made to be strapped it goes a little further then turning a knob,output has to be mesured with a multi test,and even after you do that one amp is going to be off slightly in voltage@ various hz.never the same.get a mxl-100 so you will be safe or plan on buying three more woofers
American Bass*DC Power
Tune- DMM, test tone, constant voltage, same voltage out, each amp
I know
i thought about 3 coils per amp but im not trying to mess anything up. i have 6 different 12's and 4 10's to choose from ( as soon as i get the 10's from ebay that is) that i can choose from. and the whole winter to figure this out. does anybody need a 4 12 box?
not a chance,all coils ,2 amps one circuit.or run 4 dvc subs 2 per amp and then you wont have to worry about a mxl-100
doing what I said works fine, its no different than getting a sub and running 2 or 4 amps to it, just do it right, and works fine, when I did it, I did it only once, but I have never been called back on it, and I know the guy still, he has a different set up, but subs had no issues
I only wanted to say it was an option that works fine
like i said i have alot of woofers and i am planning on getting 2 more 1500.1's. i just want something different than what everyone has in my area. no one runs 3 woofers. i dunno though. and what is a mxl-100
----reference's----
meade916
  • Who's Online   0 Members, 0 Anonymous, 3135 Guests (See full list)
