I still say as long as you understand how a cap works, and inductor works, just try yourself
because pre made cross overs are universal
I first learned on my first professional cross over I had some 6.5"s and some low Fs (950hz)silk dome tweeters, I needed to design a dipole set up
The 6.5" speakers played from 70-3500 I believe it was pretty flat, but there was mechanical noise- barely audible, but the computer picked it up at around 2200 hz, I designed the cross over for 3000 hz 6db hp/lp
an irritable sound kept bugging me in testing
did some RTA's, and sure enough, there was a spike at like 2200 hz
I had to redesign the x-over to a lower x over setting, so I re did the cross over at 2000hz @12db
buzzing gone, tweeter sounded better
If you can find graphs of the speakers you are using, try and read the slopes, and try and set up the cross over where there is a big spike in the higher audible zones- 900-5000hz
spikes in the frequency response in that area will irratate your hearing alot more than imaginable
There is also simple calculators online that will be very helpful
And learning Notch filter networks is helpful too (something else I could have used with that annoying sound)
You would pay less than buying crossovers pre made, they will be built to your speakers
you wont end up wasting money
and you will learn a fun hobby in the process
if you have any questions about it, or calculators to use, just PM me, or hit me up on AIM
Edited by Forevrbumpn
so just look at the speakers im wantings specs, then match it up with a crossover that will match that?? the whole crossover thing totally confuses me otherwise id like to try and build my own but i dont have the skill or knowledge to do so
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
