stuart_goodenough Posted September 30, 2008 Report Posted September 30, 2008 so i am running two batteries in my blazer and i'm not sure if you run the ground and power back to the second battery or run just the power and reground the second battery to the back of the vehicle
wasted ink Posted September 30, 2008 Report Posted September 30, 2008 you can do either, but its cheaper and to ground to the back. Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log
jonnylowkon Posted September 30, 2008 Report Posted September 30, 2008 but also using the chassis as a return ground for the batteries u have more of a chance for noise being introduced into ur stereo over running a dedicated ground gauge back to the battery.... if im wrong please correct me 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
qu1cks1lver56 Posted September 30, 2008 Report Posted September 30, 2008 i say ground to the frame with the front battery and the back battery and then run the power wire First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
wasted ink Posted September 30, 2008 Report Posted September 30, 2008 but also using the chassis as a return ground for the batteries u have more of a chance for noise being introduced into ur stereo over running a dedicated ground gauge back to the battery.... if im wrong please correct me find a good, solid, clean ground and you should be fine. use rough grit sandpaper (36 - 80) to scrape the paint away. Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log
