In the hummer I ran 1 1/0 from each alt to each side battery bank and a 1/0 to the main battery. 2-1/0 Grounds are from alt bracket to frame , then last battery in line to frame , from that frame location to the disto block , then to the amps.
Only fused mine before each amp.
Edit) I didn't do the jumper between the alts , was not really a noticable difference on mine.
MLA
Edited by missinglink
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
MLA
thanks bro!
ill be doing this soon... ill just have to run it w/o the jumpers and find some spare wire and do some makeshift jumpers and see if theres a diff... but you did not fuse anything untill b4 the amps??? if so thatl save me a hellova lot of fuses and terminals
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
  • 5 months later...
so running 1/0 from each alt to each battery or battery bank would you need 2 fuses per run of 1/0 or just 1 18" from each batt. or the battery bank?
2 per 1/0 run.
fuse after alt. then again b4 battery bank in the back. At least that's how I would do it. But I fused from alts to front bat. then fused right afer front bat. and again b4 battery bank in the back, per run of 1/0
Random vids of the Avalanche My link
Team Bass-Hz
