  • 3 weeks later...
T/S Specs XXX-18 new!
Fs (hz) 22.29
Qms 5.866
Vas (3ft) 5.504
Cms (mm/n) 0.119
Mms (g) 430.2
Rms (kg/s) 10.23
Xmax (mm) 30.00
Xmech (mm) 40.00
Dia (in.) 13.77
Sd (2in) 149.10
Vd (3ft) 0.136
Qes 0.191
Re (ohms) 1.20
Z (ohms) 1.2
BL 19.47
Pe (watts) 10000
Qts 0.185
No 0.875
1w/1m SPL 91.40
2.8v SPL 99.81
VC DIA (IN) 4.0
VC (Ohms) QVC 1.2
M-vd (3ft) 0.6000
Cut-out (in) 16.750
Depth (in) 11.125
Min. Sealed N / A
Qtc N / A
F3 N / A
Opt. Sealed N / A
Qtc N / A
F3 N / A
Max. Sealed N / A
Qtc N / A
F3 N / A
Min. Vented 4.00
port (4) 4x15
Fb 49.91
F3 43.54
Opt. Vented 6.00
port (3) 6x13.5
Fb 50.00
F3 42.71
Max. Vented 8.00
port (4) 6x12
Fb 49.84
F3 42.24
Edited by deezydee
WHAT THE F#CK?
is up with that last post
looking at the specs, it looks like the perfect subwoofer
But most people don't use 4" coil subs for the fact the weight of the coil kills on the spl side
and a 5" coil, well, thats just ridicules
Also the subs posted are 15s not the 18s
and in the T/S parameters, wtf is up with a 13.77" diameter? still think those specs are on the 15"
13.77 sounds like the cone diameter of a 15" cone
Specs are for the 18" a XXX15 has a cone diameter of 12.220 according to the spec sheet soundstream sent me.
