Andrew2944r Posted October 9, 2008 Report Posted October 9, 2008 Damn its alot of work getting a Dual set up installed, especially running 4/0 wire. Almost done! Team Ampere Audio
droopy89 Posted October 9, 2008 Report Posted October 9, 2008 Are you done yet?? 1997 S10 EC Whats in it 106.9 Sq.ft. Hushmat DB Elec. 250 amp alt. HC800&HC1400 MLA Module Alpine 9886 Knukonceptz wires Clarion EQS746 poopy Alpine door co-ax's Change IS Coming
Andrew2944r Posted October 9, 2008 Author Report Posted October 9, 2008 Are you done yet?? Done, Finished Product - DMM Low pass MLA @ 14.8 Volts DMM High Pass MLA @ 15.6 Volts Team Ampere Audio
Andrew2944r Posted October 9, 2008 Author Report Posted October 9, 2008 The Alt on the left mid ways right behind it, running right under to the right of the Air Cleaner. Team Ampere Audio
dmanson Posted October 10, 2008 Report Posted October 10, 2008 so how's that HO alternator help your system out? 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Dr. Johnson Posted October 10, 2008 Report Posted October 10, 2008 So you have 1 4/0 run from one HO Alt to the back?
thien211 Posted October 22, 2008 Report Posted October 22, 2008 may i know how to fit the alt, my car is land cruser 2000, the belt and all thing jus like compacted. must a lot of work, rite.
