Noise In Sub
ok well when i turn on my truck the sub like beats to to the motor. i rewired the rca. and i was wondering what might cause it to make the noise from the motor.
thanks
split
Live Fast Die Fun!!!!
Use it or lose it
i noticed the noise happens when you trun on anything electircal. and was wondering if you guys might know wat is causing it to make the noise.
Use it or lose it
ground loop.
check all of your grounding to make sure its a good ground, usually thats the cause of most noise issues youll encounter
and make sure ur rcas are away from power wire, and its grounded ina good spot with no paint on it, umm i had a bad ground loop problem till i switched out headunits, my pioneer 860 dont have no ground loop but the 680 i had in there did, and its not the wireing cause it does it now in my geo, might be a bad ground somewere, what kinda equitment u got?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
no theres somethin wrong inside cause it done it in 2 cars and i had to ground the rcas thats how its done now
so could it be the headunit ground? i have the pioneer 1900 version headunit and sochce wiring kit.
Use it or lose it
how do you ground rcas. and i noticed only one rca plug works.
Use it or lose it
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
