Guest Just_Rob Posted October 21, 2008 Report Posted October 21, 2008 Just to clarify a couple of things.... Your truck *should* have a 150 Amp Denso alternator, if its a Lariat, then 99.9999% sure and yes, it is PCM controlled, all F-150's from '04--> were.. For doing what your talking about doing, put dual alts on it and forget it... A GOOD dual alt kit for your truck is definitely the way to go, especially if you want to drain the batteries down... We dont recommend doing it, but if your going to do it then definitely go the dual route, you'll be WAY happy you did.. When you figure the time and $$$ investment in your system, do you not want to enjoy it?? We did a similar setup for a customer about 8 months ago running 2 145A alternators on his V-10 Excursion (different setup than your truck) and I get at LEAST one call a month from him just to tell me how much he loves it and how glad he is he went duals and he does the same thing you are intending on doing.. If your going to go duals and run the batteries down then stick with OEM output alternators, you can run the hell out of them and they wont generate enough heat in most instances to self disentigrate.. Just my .02...
Fish Chris Posted October 22, 2008 Author Report Posted October 22, 2008 Thanks guys, but..... Link, you said my alternator only puts out 105 amps ? Just_Rob, you said 150 amps ? Then on the Ford F150 forum, they were saying 130...... What does it really do ? Oh, my truck isn't a Lariat though.... It's an XLT. Hmmmm..... Fish
