w87will Posted October 19, 2008 Report Posted October 19, 2008 Ive decided to buy some new speakers and and a nice amp to power them. I just want to make sure everything will work together before the purchase. Im going with a set of Hertz HSK165 and also HCX165. Found an Alpine which seems to be the perfect size amp for what im looking for I believe, it the Alpine PDX-4.100. Says it does 100x4 @ 4ohms. Links: http://www.hertzaudiovideo.com/default_en.htm http://www.bestbuy.com/site/olspage.jsp?sk...d=1199494646397 This is the correct size amp for powering those two sets of speakers correct? Also Im kind of new to setting up components. I will most likely have acouple questions about adjusting the settings on the amp correctly. And will the mid be fine "free-aired" in the stock door location or will it require some type of small enclosure/box. Quote
ChevyBoy Posted October 19, 2008 Report Posted October 19, 2008 thatll work just fine. but for a little bit more "punch" out of the mids, you should build a little enclosure or put them foam baffles in your door. Quote
w87will Posted October 19, 2008 Author Report Posted October 19, 2008 Cool thanks. Ill probably just get the foam baffles then...that'll be alot easier. I saw you have or had the Hi-energies. Would you say I'd notice a big difference switching from my infinity ref. to these Hertz? Quote
ChevyBoy Posted October 19, 2008 Report Posted October 19, 2008 i havent really messed with the infinitys except at best buy, and i didnt really like them. so i would think u would notice a good difference.. i had them in my truck and plan on getting them again when money allows me to. Quote
