4 Atomic Apxx 15" 4rth Order Bandpass Wall Build
the 4 sealed box's porting into the cab via the loading wall
Oh i see...Thanks
1996 Chevy impala SS
Alpine CDA-9886
Vibe audio black death 6 1/2 components/Swiss audio crossovers
Vibe audio black death 6/9s
yellow top+2 125 ah deep cycles
[email protected]
Aq-4
Audioque hdc3-18 copp. D1 6.0cu/31hz
2 runs of 0/1 stock 140 amp alt big 3
Mark Sparrow
thatd be different so when your bassracing people could actually hear some music instead of slaping metal, but i wouldnt have them on all the time
exactly i or i was thinking of putting them in the center console running off deck power for that extra little loudness
or having 4 speakers per rear door facing the glass
R.I.P!
(Nov-29-2009)
92 explorer
current build
did some testing today
did a 151 at 46hz sealed up amps wired to .7 each then did a 153.8 at 46hz sealed up amps wired down to .175 each amp
needs alot of testing before i get louder
also did a 155 and some change at 46 hz in the kick
didnt get any pics of the scores cause im not happy with the scores yet
but next week i should have some more updates with scores
also started building a box for buddys street B setup
he'll be running 2 12" atomic apx's and a DD Z1
should have some pics up soon
R.I.P!
(Nov-29-2009)
92 explorer
current build
since testing i've gone and threw in a 12" sonotube cut in half
to see if a rounded over loading wall gains me any (dont mind the ductape) its screwed in
Posted Image
Posted Image
also took the sub with that blew a dustcap out to reglue it
Posted Image
next to the apx 12"
Posted Image
Posted Image
my dustcap on the 12"
Posted Image
Posted Image
and the normal tiny cone
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
some little updates started working on the rear speakers
Posted Image
not sure if i want to angle them or have them straight up
Posted Image
Posted Image
and for the hell of it some pictures of the neil young concert was a packed show every seat was filled
Posted Image
Posted Image
amazing concert
R.I.P!
(Nov-29-2009)
92 explorer
current build
Sexy :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
so with these 8 speakers it will make a total of 20 speakers in the exploder she gets stupid loud already but i want more
once i get paid i'm going to be looking into some super tweeters for upfront and possibly a center channel but the weathers not so nice its almost may and it just snowed
Posted Image
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
so i got both sets of rear speakers working but ones not working right i somehow wired it to 0.4 ohm so i said screw it and just left them unhooked and started to tackle the center console i plan on painting it and instead of cutting corners and just painting without prepping it i decided to add some filler and make sure theres no cracks or nothing and make evertything nice and pretty for paint
Posted Image
Posted Image
Posted Image
and the reason why im not out there now sanding it
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
