Split9112 Posted October 27, 2008 Report Share Posted October 27, 2008 i was thinking of wiring up a battery in the back of my truck. b/c i have to wire up two amps and one takes 0 guage and the other takes 4 gauge. would a second battery be best or how would i wire up both to the one battery? i am a big idiot from time to time and can think of anything. so thanks for the help still a big noob Quote Live Fast Die Fun!!!! Use it or lose it Link to comment Share on other sites More sharing options...
DUBIE Posted October 30, 2008 Report Share Posted October 30, 2008 i was thinking of wiring up a battery in the back of my truck. b/c i have to wire up two amps and one takes 0 guage and the other takes 4 gauge. would a second battery be best or how would i wire up both to the one battery? i am a big idiot from time to time and can think of anything. so thanks for the helpstill a big noob just wire (+)from front battery with (+)to back battery and (-)from front and (-) to back...and if you had extra more battery(s) later do the same thing with them... Quote Link to comment Share on other sites More sharing options...
lance_aka_64 Posted October 30, 2008 Report Share Posted October 30, 2008 you don't have to run a - all the way up front. just ground it like you ground your amp. unless you have money for another run of wire. Quote Need any thing chromed? Hit me up!!! gamer tag: (360) mEmEnToMoRi64 My Myspace refs: from here: RollinSoLow, Derrick824, Ray from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground) from ca.com: alxmlr789,photocrazy8 Link to comment Share on other sites More sharing options...
alvitae Posted October 30, 2008 Report Share Posted October 30, 2008 If one amp takes 0awg and another 4awg, You can get a distribution block. Something along these lines maybe. Dist block Quote Link to comment Share on other sites More sharing options...
DUBIE Posted October 30, 2008 Report Share Posted October 30, 2008 you don't have to run a - all the way up front. just ground it like you ground your amp. unless you have money for another run of wire. oh yeah my bad brotha!..i forgot about that...half awake overhere!..yea what ^^^^ he said...keep in mind keep your ground as short as possible... Quote Link to comment Share on other sites More sharing options...
E a r t h Posted October 31, 2008 Report Share Posted October 31, 2008 You can use 1/0 to 4 gauge reducers, if you don't want to do a run of 4 gauge for the small amp Quote Link to comment Share on other sites More sharing options...
Split9112 Posted November 1, 2008 Author Report Share Posted November 1, 2008 you don't have to run a - all the way up front. just ground it like you ground your amp. unless you have money for another run of wire. but then would the battery keep the amp on the whole time or would it shut off when i turn the truck off? Quote Live Fast Die Fun!!!! Use it or lose it Link to comment Share on other sites More sharing options...
Got_Bass89 Posted November 1, 2008 Report Share Posted November 1, 2008 You don't need any distro blocks.. Your back batter pretty much is a distro block... Wires off back batt to amp.. Don't matter what guage.. Quote Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack Link to comment Share on other sites More sharing options...
Got_Bass89 Posted November 1, 2008 Report Share Posted November 1, 2008 Your remote wire turns your amp on/off... Not your batterys Quote Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack Link to comment Share on other sites More sharing options...
raytard Posted November 1, 2008 Report Share Posted November 1, 2008 if you get a battery with the bolt type posts, this is super easy run 0g from front + to back battery, use a ring terminal to the bolt, from the same bolt, run wires to your amps, with whatever gauge wire and ring terminal they require. run a 0g ground from the negative terminal to the chassis, and then using the same guages and ring terminals, run ground lines to the amps. basically front batt to reaar, and rear to amps, so u have 3 terminals stacked on the bolt, and then chassis to neg, and then to neg of amps, so there is again, 3 stacked on the one bolt. Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
