Mechman=a++++++++++++++++++++++++++
If your thinking about going to mechamn DO NOT hesitate. TOP notch servide and product. Alternato was shipped VERY nicely. You could put glass into it and drop it off a building and not have it shatter. Used EVERY bit of space available in the casings. You can look into the casing and not see 1 bit of space not was not used to "beef" this thing up. Came with 0 gauge o-rings t install the alternator. Also came with an entire mounting bracket instead of spacers. Already wired up the external regulator with some nice heat shrink and heat flex i believe its called. Also comesm with a test results sheet. If you have any other questions on Mechman pm me.
Car Audio + Bodyboarding/Longboarding = LIFE!!!
so when am i installing this beutifal peice of equiptment...
99 4runner
walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar
orion hcca 8000.1d
8 Polk audio mm 691 6x9
2 2000x4 hifonics
320 amp singer alt
3 g31
1 baby seat 1 booster seat and daily driven!
so what size alternator did you get?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
