Guest xXxTeamKickerxXx Posted November 10, 2008 Report Posted November 10, 2008 can you run a 1000.1 kicker amp on a 12" cvx? has anyone every tried it?
banginAltima Posted November 10, 2008 Report Posted November 10, 2008 You can run a 5000 watt amp on a 150 watt rms sub as long as everything is set right.... If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Guest xXxTeamKickerxXx Posted November 10, 2008 Report Posted November 10, 2008 You can run a 5000 watt amp on a 150 watt rms sub as long as everything is set right.... yea i know that i just dont want to f**k it up but im tryin to max the sub out with out blowin it, it's in a ported memphis box
Dale Posted November 10, 2008 Report Posted November 10, 2008 You can run a 5000 watt amp on a 150 watt rms sub as long as everything is set right.... lol very true
Guest xXxTeamKickerxXx Posted November 10, 2008 Report Posted November 10, 2008 nevermind just poped the sub lol back to my 15 :01nocomment8so:
banginAltima Posted November 10, 2008 Report Posted November 10, 2008 You need to use your nose and your hand... Start with the amp gain and any bass boost turned all the way down. Play music for 5 or so minutes, if no voice coil smell and the sub isn't hot turn the amp up some... repete... Or if you have a clamp meter and a voltage meter, you can do the math. If you are worried wire the sub to the highest ohm load. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
