also for a 99 s10 blazer.....
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Short update, 1- AX3200DE DOA. :shok: .. returned to Dealer new one shouold be here delivered on Monday.. :search:
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
nice potna. i need someone to come up with a dual alt bracket of some sort for a 2004 Ford Expedition ...... haven't seen it done yet.
5.4 liter????
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
It will be a home made looking as mine not all CNC'd and pretty...
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
can we get those fusion comps in the US? I see the 3 way for like 60 bucks on one site but cant figure if its american or not. I'm curious how they are. May have to run some.
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
did you change the pulley on the alt?
Yes, I made one.. I ordered the large, dual V pulley. And when I decided to move the Alt I had to switch to the Dual "Small V-belts..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
what kinda wire are thems..also how did you hook up the alt...did you just use one wire to hook up
The wire is audio pipe 1/0, I wired it in conjuction with the stock Alt. And yes I used the one wire hook-up...
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
Yes, they came from the US. This is my first set of Fusion, and they are planning to go in the A-pillars, I haven't found a good way the get rid of the Green yet, so I dont have them in yet.. I picked them up for about the same price, so the ones you found should be the same one's.. They look very beefy, the only I see that I don't like is the huge crossover...The 4 and 6.5 both have vented voice coils.
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
