Blackedout Posted November 22, 2008 Report Posted November 22, 2008 30- 40 watts. Do you have flux? 60/40 rosin core solder? Quote Trunk Build Log
Stephen Posted November 22, 2008 Report Posted November 22, 2008 http://www.homedepot.com/webapp/wcs/stores...uctId=100391613 Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
sierra mist Posted November 22, 2008 Author Report Posted November 22, 2008 30- 40 watts. Do you have flux? 60/40 rosin core solder?I got the 40 watt Weller from HD. The solder is 60/40 rosin core solder with 0.32 dia. Quote
sierra mist Posted November 22, 2008 Author Report Posted November 22, 2008 http://www.homedepot.com/webapp/wcs/stores...uctId=100391613 Yep, this is the one I bought. I'm glad it worked for you? How long did you let the iron heat up? Almost how long did you hold the tip of the iron on the wire? I asked because every iron is different. Since we have the same one, I figured you would be the best person to ask Quote
Stephen Posted November 22, 2008 Report Posted November 22, 2008 Yep, this is the one I bought. I'm glad it worked for you? How long did you let the iron heat up? Almost how long did you hold the tip of the iron on the wire? I asked because every iron is different. Since we have the same one, I figured you would be the best person to ask maybe 2 mins heat up time. I just put the iron in the middle of the wire then push solder at the tip where its sitting on thee wire. After that use the tip to move it around. Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
