Box Help Please
Hi guy an gals,
This is probably posted somewhere else in this forum but I cant find it, I need some advice please please please. :good:
picture this if you will: I'm building a custom box for the back of my 4x4 and i have everythin perfect, except the front.
I have been debating before i cut anything out of the front should I: A: leave the ports where they are
or B: move ports to outer edge??
I'm really stumped and I thought I'd tickle someone elses brain. :crazy:
This is My New Box
Any advice would be much appreciated :)
Edited by bigman2004_8
what subs/what amp
how big are those ports and what length
imo id rather have the ports in the middle so there arent any issues with them being too close to the enclosures walls
common chamber boxes are notorious for being louder than a partitioned box of the same specs so long as the common chamber box is well braced internally
what subs/what amp
Hi m8, Subs and Amp are from a small local company close to me in th UK.
the ports are 27CM deep, 10CM diameter,
Thanks for the swift reply,
anything else just ask :)
QUICK EDIT
SUBS: http://www.theloudest.co.uk/?sectionid=2&a...p;product_id=85
AMP: http://www.theloudest.co.uk/?sectionid=2&a...p;product_id=91
Sorry forgot to add last time :)
as a very rough estimate...but i think its pretty close
ur looking at
[email protected]
5sqin/cuft port surface area
id leave the ports where they are... but ideally u should have 4 10cm ports ~51-59 cm long depending on tuning, which means ud need an elbow
if u notice the sound of chuffing, huffing, woofing or any sounds like that means there isnt enough port surface area
normally the sounds exiting the port should sound smooth and transitional... it should be obvious if u need more ports
goodluck
ur looking at
[email protected]
goodluck
Thanks for the luck m8,
the ports I am using are from this enclosure: http://www.theloudest.co.uk/?sectionid=2&a...p;product_id=95
The only reason i didnt use 2 of there boxes is cos ive only got 100cm boot space, width wise, so i built a custom one.
I want to get a rough idea what its going to sound like, how do you think it is going to sound??
Many thanks
Noticing your sig....just a word of advice....peak power means nothing.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
I kinda gathered that m8 but i thought id post it as i just came in from work and didnt think lol
Thanks for the advice ill change it now :)
Many thanks
well the box on the site ur refering to was tuned to 50hz... which is 15hz above the highest i would ever tune to listen to music... that said, the box u made has a small amount of port area, large volume and low tuning... so it should sound pretty good from 30-50hz and there might be some dropoff above since theres not enough port area... but it should sound pretty good, amazing compared to the prefab one tuned to 50hz
I hope this is going to sound awesome as i have 2 15's in there while this is getting built but there in a sealed enclosure, but sayin that when driving down the road or pullin up in garage they shake the goolies out of most things around it, i just hope what im building will be better than what i have....... HOPE :)
Thanks for the advice m8 :)
Anything else you think of that may help would be muchly appreciated :)
So weve all agreed, I should leave the ports where they are :)
By the way the blueprint has NOT had the speaker or port holes drawn to scale.
I Duck Taped the ports into position just to get an idea :)
And with the front resting on :)
Thanks for all the advice guys :)
  • Who's Online   0 Members, 0 Anonymous, 565 Guests (See full list)
