penguin3820 Posted November 27, 2008 Report Posted November 27, 2008 I knew my electrical needed upgrading...but waited too long. my initial idea is get a d3100 as a main battery...then the new excessive amperage 350 amp alt. Its going to be running 2 four channels and an hk4000d.... will this be ok? or will i need a battery on top of that? help needed. If i can't get this sorted out and fixed 2004 F150 super crew 15" fi btl Ma Audio hk4000d
Andrew2944r Posted November 27, 2008 Report Posted November 27, 2008 2 - 3100 and http://www.dcpowerinc.com/home.php Alt Team Ampere Audio
penguin3820 Posted November 27, 2008 Author Report Posted November 27, 2008 2 - 3100and http://www.dcpowerinc.com/home.php Alt use a 3100 as a main and 2nd? 2004 F150 super crew 15" fi btl Ma Audio hk4000d
Andrew2944r Posted November 27, 2008 Report Posted November 27, 2008 whatever fits up front I would use a 2400 and a 3100 in rear Team Ampere Audio
penguin3820 Posted November 27, 2008 Author Report Posted November 27, 2008 whatever fits up front I would use a 2400 and a 3100 in rear ok thanks. i emailed the the alt guys. Ill check dimensions for up front. thanks for the help 2004 F150 super crew 15" fi btl Ma Audio hk4000d
Andrew2944r Posted November 27, 2008 Report Posted November 27, 2008 They have a toll free #, I would call, they allways answer. Team Ampere Audio
dmanson Posted November 27, 2008 Report Posted November 27, 2008 definitely at least 2 batteries ........... 3 if possible brotha. definitely do at least two runs of 1/0 (one run is good for around 3500rms depending on the manufacture of the wire). good luck 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
korey_hofer Posted November 27, 2008 Report Posted November 27, 2008 or you could get the EA alt that is streetable and puts out 350 amps previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
penguin3820 Posted November 27, 2008 Author Report Posted November 27, 2008 or you could get the EA alt that is streetable and puts out 350 amps what do u mean? the one i was looking at is the one that is going into production now/soon. the new 350 amp large case ford alt http://www.realmofexcursion.com/forum/showthread.php?t=58502 2004 F150 super crew 15" fi btl Ma Audio hk4000d
