Is it possible to connect one bass knob to 2 amps? I'm assuming you can just cut the wiring open and solder another connector to it, but I'm not familiar with what type of wire it is so I'm not sure if that would work.
chicken is basically the native american hulk, you think he broke that curb with his rim? think again, that was merely him stubbing his toe.
i wouldnt do that. what kind of amp do you have. some you can link together via RCAs and have one master one slave and control it through 1 bass knob
NoFearX18 said:
trainman0978 said:
I have an Audiobahn a8000t and was thinking about getting another one but don't want to run 2 bass knobs up front.
cant you just get the rockford fosgate sixty processor?...steve has that...he has 4 amp for woofas and he only uses bass knob to control all 4 woofas
I know there's solutions like that, but I don't think that's necessary for my setup. I'm trying to save myself some money but have it work properly.
even if he didnt have the 360 processor he still could have run rcas through the input and pass thru and had it run off of 1 remote bass.
NoFearX18 said:
So if I connect the 2 amps together using the line out of one into the line in on the other, then the bass knob plugged into the first amp would control both?
if your amp has that and has a master/slave option then yes. you run 1 set of RCAS into 1 amps input and another set of RCAS from the first amps passthrough/output to the second amps input set the first amp to master and the second to slave
NoFearX18 said:
Perfect, thank you sir.
i was just saying..i know how expensive those things are
