its gonna be real tight everything wise, it would be nice to have an extra~3cubes so you could fit an optimum box
...or just use 3 and throw one in your girls car or something...hint hint
noticed you have individual amps on each sub, sooo grab one more, move your rack a little bit to compensate, do 3 wide which would look ill
38wX24hX14d, port 26 wide, 3 high, 20 deep, gives 1.55cube per sub, 16.8sq in port per cube, 40hz tuning , very close to optimum specs from kicker, use some poly fill if you want lower curve and "smoother response" (port 20wx3hx27l gives 32hz tuning, 13sqin/cube if u wanna tune lower)
may be a consideration, i think 3 across would look better too
Team DC
Thanks for your help ray. I was thinking about the 4 10's being on top though. I have to go pick up the other subs right now. PM your email address and I will get back with you later.
James, thats the minimum measurement up top. I could get 16 maybe 17, but I am being conservative. I will be back in a bit.
No matter how hot she is, someone, somewhere, is sick of her shit.
99 Tahoe:
2-10" MA Audio
4-6.5" Kenwood door speakers
Total Amp
Sony HU
The kicker amps are running my 4 kicker 6.5's in the doors. I will be using a MTX 6500D for the subs. Right now I am running D4 coils and the amp is seeing 1ohm. The amp plays fine at 1 ohm and barely gets warm, but I have blown both of the 20amp fuses on the amp a couple times. So I'm thinking with 4 D4 coils the amp will be seeing 2 ohms which should stop it from popping fuses.
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
def a good plan, just saying though, if you halve the power and double the cone area, most likely you're going to be right around where you started db wise
p.s. your sig is awesome
Team DC
Thanks bro.
Edited by CrashHole
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
Here you go ray, final measurements. 38L, 22H, 19D(bottom) 13D(Top) Wedge style design. This will allow me more room. What are you thinking?
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
This is what we built. The box is tuned to 40hz. I just need more power now!
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
looks good i would have went with this myself but to each there own
R.I.P!
(Nov-29-2009)
92 explorer
current build
Would the box or port being to big/small cause my subs to pop? It does it on 2,3, or all 4 subs. It's mainly on the low notes.
99 Tahoe:
2-10" MA Audio
Total Amp
Sony HU
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
