Forevrbumpn Posted January 22, 2007 Report Share Posted January 22, 2007 Bat cap, reason why is cuz they charge, and sicharge super fast, no need to worry about charging issues. Its like buying a Cap, but a lot higher Farads- Bat, and Alt later man, wait for something to come out for that car first Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Low n Loud Posted January 22, 2007 Author Report Share Posted January 22, 2007 Bat cap, reason why is cuz they charge, and sicharge super fast, no need to worry about charging issues. Its like buying a Cap, but a lot higher Farads- Bat, and Alt later man, wait for something to come out for that car first i was on batcap.net for a while and it seems simple to install. on their site it says to always fuse a power source. obviously i have a fuse going from the battery to the batcap, but do i need a fuse going from the batcap to the amp? Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 22, 2007 Report Share Posted January 22, 2007 it would be recommended to fuse bat cap to amp. always fuse after a battery. Quote Link to comment Share on other sites More sharing options...
dmanson Posted January 23, 2007 Report Share Posted January 23, 2007 it would be recommended to fuse bat cap to amp. always fuse after a battery. that's extra protection ..... having a fuse between the batcap and amp. as stated on the diagram. we all know to fuse after the underhood battery and then be sure to fuse before the batcap also since it somewhat works like a battery. now if you'd like to fuse after the batcap then by all means go ahead. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Ridin Clean Posted January 23, 2007 Report Share Posted January 23, 2007 Also very important for BatCap you must run a dedicated Power + and Ground - ( From the main Battery ) you cannot just run a chassis ground..and a minimum of 4 gauge nothing less ..thicker the better Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted January 23, 2007 Report Share Posted January 23, 2007 actually you dont have to run a ground. it would be recommended, but you dont have to. http://batcap.net/Indexnew5.htm Quote Link to comment Share on other sites More sharing options...
Ridin Clean Posted January 23, 2007 Report Share Posted January 23, 2007 If you want it Right run the ground!..who wants to be OK Quote Link to comment Share on other sites More sharing options...
dmanson Posted January 23, 2007 Report Share Posted January 23, 2007 that was a major problem at the audio shop about running an extra ground from the front to batcap. most shops said to just stick with the OK diagram. but as it shows the batcap is grounded to the amp and that's impossible because a amp only has one ground. now you could use the same grounding point as the amp. but we all know capacitors and amps should be grounded separately. regardless i have still heard good things about the batcap. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
Ridin Clean Posted January 23, 2007 Report Share Posted January 23, 2007 BatCaps are great!! just run the groud from the battery you will never have a problem this way. Quote Link to comment Share on other sites More sharing options...
Low n Loud Posted January 24, 2007 Author Report Share Posted January 24, 2007 yea im going to be using 1/0 anyway. the fuse i have running from the batt to the batcap is 250amp, do i need the same amp rating from the batcap to the amplifier also? Quote Link to comment Share on other sites More sharing options...
