uhoh_45 Posted December 10, 2008 Report Posted December 10, 2008 so im screwing around with my 360 checking out the new layout and shit and i click on the game i have in and it says install game so i do it takes up 6.5 gigs of memory and i cant even play the game without the disk in does anyone know what this features for? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
now534 Posted December 11, 2008 Report Posted December 11, 2008 all it really does is create less noise due to it not having to spin the disc while in the game it only has to have the disc in to boot the game more less but requres it to stay in at all times (gay). i believe it keeps your xbox cooler too so it doesn't overheat. and last but not least it would probably let it live longer. Kind of a waste of space though unless you have a elite hard drive or the 120gb one.
Sampsonite Posted December 11, 2008 Report Posted December 11, 2008 ghey.. I have the extra external fan and heat hasn't been an issue for me --Sampson 816-591-6592 www.kcrimshop.com
uhoh_45 Posted December 11, 2008 Author Report Posted December 11, 2008 yeah i've got an elite and only 22 gigs left i have alot of demos and yeah i figured it just helped loading and cooling but i figured 6 gigs was alot for that R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
now534 Posted December 11, 2008 Report Posted December 11, 2008 is it the one that attaches to the back of the xbox with the power supply or whatever? if so those void the warrenty i have heard. i keep mine in a well ventilated area that doesn't absorb a lot of heat.
MTX J30 Posted January 11, 2009 Report Posted January 11, 2009 i heard it helps with loading times but idk if thats true or not. i dont think its worth it, unless it also helps with lag. Once or twice I have missed having a back seat / rear hatch, but all in all people love to see a walled vehcile. It just screams "i'm not fucking around with my setup, im loud"
Lice_01 Posted January 15, 2009 Report Posted January 15, 2009 Yeah what it does is it loads the whole game to the hard drive, Its helps with noise issues from the DVD drive and decreases loading times. It also saves your laser some life. The reason you need the disc in the drive is so you don't go rent a game install it to the HD and return it.
