this is all interesting.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
We used to charge our optimas til the top started melting, wasnt good for their lifespan but it sure helped out scores in Street max. ID venture to say you over charged them, and they might not be completely shot but id go ahead and start shopping for some new batts ;)
I have 2 of those batts. & a MLA, my batts. dont smoke :unsure:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Is it possible that because they were charged with a dedicated alternator and MLA module for 2 weeks straight with only 400 watts max of draw that they were over charged?
If this "dedicated alternator" setup had the batteries connected to the slave alternator, with no voltage reference to the master alternator, then yes you have been overcharging your batteries.
Multiple alternators should be connected to ALL of the batteries in the bank. Sharing the load between all of the alternators and batteries in the system is the only way a dual alternator MLA module should be hooked up.
Clean your batteries with baking soda & water to get rid of the acid that vented. Check the resting voltage after they have cooled off.
A 4 gauge jumper wire between the two alternator output studs is recomended if you have seperate batttery banks.
'Link
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
baking soda and water? hmm, i am for sure gonna go try that, thanks. it makes sense though =x
When running multi alt set ups we use your cars voltage reference as our guide. So by doing 1 alt to car and 1 alt for sub amp/batteries then the sub/amp batteries have no reference point to go off of and will run 17/18/19v because its "kinda" unregulated. Your front battery / alt sences car draw with the reference point then the 2nd alt sees the same draw/load without a responce back from the car. So all it sees is a load demand and runs wide open pretty much.
We can do split system set ups as well they are our "Stand Alone" modules , which in these units we build the reference point into the module.
Hope this helps a little more,
Chris@ MLA
Edited by missinglink
missinglinkaudio
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
