kentb Posted December 13, 2008 Report Posted December 13, 2008 here is the manual on the scytek astra 777 alarm and this is the wiring diagram for my 2000 ford explorer i already mounted the brain, the siren and the shock sensor. also wired them. i haven't wired the horn, parking lights and the doors. i need help on this. the wiring is kinda confusing. for the horn, it says that the wire is negative and must use a relay, how will i wire a relay with a negative wire? for the parking lights, do i just choose which wire polarity i will hook up from my car and just set the jumper? how will i know if the parking lights exceeds 10 amps and needs a fuse? i'm totally confused on how to wire the doors. don't need the triggers just need the unlock and lock feature. i suck at this.. thanks in advance to anyone that can help! Quote New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Shyne151 Posted December 14, 2008 Report Posted December 14, 2008 I don't know how much I would trust that diagram, are you having problems finding some of the wires? because directechs is different on alot of those wires: 2000 Ford Explorer DirectWire 2.0 Vehicle Information All Products Item Wire Color Polarity Wire Location 12 Volts yellow + ignition harness Second 12 Volts Starter red/lt. blue + ignition harness Second Starter Ignition green/purple + ignition harness Two wires each at switch, both are common, only need to power 1 each during remote start. Second Ignition Third Ignition Accessory gray/yellow + ignition harness Two wires each at switch, both are common, only need to power 1 each during remote start. Second Accessory black/green + ignition harness Third Accessory Keysense Data Bus Can Bus High Can Bus Low Can Bus Sw Power Lock pink/yellow - driver kick panel Power Unlock pink/green - driver kick panel Lock Motor pink/black driver kick panel Driver Unlock Motor red/orange driver kick panel Passenger Unlock Motor pink/orange driver kick panel You may also use the pink/green power unlock wire. Parking Lights (-) white/purple driver kick panel Parking Lights (+) purple/white driver kick panel Also found to be white/black at the rear of the switch. Hazards Turn Signal (Left) Turn Signal (Right) Headlight red/yellow + light switch AutoLights Reverse Light Left Front Door Trigger - In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. green/yellow for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information. Right Front Door Trigger Left Rear Door Trigger Right Rear Door Trigger Dome Supervision use door trigger Trunk/Hatch Pin white/purple - driver kick panel Rear Glass Pin Hood Pin tan/lt.green - driver kick panel Trunk/Hatch Release Trunk Release Motor Fuel Door Release Power Sliding Door (Left) Power Sliding Door (Right) Factory Alarm Arm arms on lock Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm. Factory Alarm Disarm dk. green/purple - driver kick panel Disarm No Unlock Trunk Alarm Shunt Tachometer tan/yellow PCM The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster. Wait to Start Neutral Safety Clutch Pedal Fuel Pump Rear Defroster Mirror Defroster Left Front Heated Seat Right Front Heated Seat Speed Sense gray/black 8 PCM The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster. Brake Wire lt.green + driver kick panel Parking Brake Horn Trigger yellow/lt. green - steering column The outputs on your alarm for the door locks should be negative, I would try hooking them straight up to the wires that are listed above for doorlocks(test them first of course).... this works with DEI units... if the pulse will be strong enough with your scytek, idk. Why are you hooking up horn wire, if you have the siren under the hood? anyways that should also be a negative trigger... just hook it straight up. Most of the time these negative triggers are just activating a relay... so you don't need a relay to activate a relay. I would hook the positive parking lights up at the switch... shouldn't exceed 10amps... if you are really worried get negative in the kick panel. Sorry it took so long to respond, been busy at the shop. Post up if you have any other questions. Quote -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
