First Time Installing Alarm, Need Help.
here is the manual on the scytek astra 777 alarm
and this is the wiring diagram for my 2000 ford explorer
i already mounted the brain, the siren and the shock sensor.
also wired them.
i haven't wired the horn, parking lights and the doors. i need help on this.
the wiring is kinda confusing.
for the horn, it says that the wire is negative and must use a relay, how will i wire a relay with a negative wire?
for the parking lights, do i just choose which wire polarity i will hook up from my car and just set the jumper? how will i know if the parking lights exceeds 10 amps and needs a fuse?
i'm totally confused on how to wire the doors. don't need the triggers just need the unlock and lock feature.
i suck at this..
thanks in advance to anyone that can help!
I don't know how much I would trust that diagram, are you having problems finding some of the wires? because directechs is different on alot of those wires:
2000 Ford Explorer DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts yellow + ignition harness
Second 12 Volts
Starter red/lt. blue + ignition harness
Second Starter
Ignition green/purple + ignition harness
Two wires each at switch, both are common, only need to power 1 each during remote start.
Second Ignition
Third Ignition
Accessory gray/yellow + ignition harness
Second Accessory black/green + ignition harness
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock pink/yellow - driver kick panel
Power Unlock pink/green - driver kick panel
Lock Motor pink/black driver kick panel
Driver Unlock Motor red/orange driver kick panel
Passenger Unlock Motor pink/orange driver kick panel
You may also use the pink/green power unlock wire.
Parking Lights (-) white/purple driver kick panel
Parking Lights (+) purple/white driver kick panel
Also found to be white/black at the rear of the switch.
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight red/yellow + light switch
AutoLights
Reverse Light
Left Front Door Trigger -
In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. green/yellow for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision use door trigger
Trunk/Hatch Pin white/purple - driver kick panel
Rear Glass Pin
Hood Pin tan/lt.green - driver kick panel
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm arms on lock
Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.
Factory Alarm Disarm dk. green/purple - driver kick panel
Disarm No Unlock
Trunk Alarm Shunt
Tachometer tan/yellow PCM
The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster.
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense gray/black 8 PCM
Brake Wire lt.green + driver kick panel
Parking Brake
Horn Trigger yellow/lt. green - steering column
The outputs on your alarm for the door locks should be negative, I would try hooking them straight up to the wires that are listed above for doorlocks(test them first of course).... this works with DEI units... if the pulse will be strong enough with your scytek, idk.
Why are you hooking up horn wire, if you have the siren under the hood? anyways that should also be a negative trigger... just hook it straight up. Most of the time these negative triggers are just activating a relay... so you don't need a relay to activate a relay.
I would hook the positive parking lights up at the switch... shouldn't exceed 10amps... if you are really worried get negative in the kick panel.
Sorry it took so long to respond, been busy at the shop. Post up if you have any other questions.
-Installer for Duke's Car Stereo
2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
RF Punch 6.5" components and MB Quart Premium 6x9"s
Powermaster Alternator, YellowTop D34, Vmax CT1000
  • Who's Online   1 Member, 0 Anonymous, 1210 Guests (See full list)
