I am gonna need 2 alts for my setup but I am trying to find a dual alt bracket if their is such. And was wondering how these would be hooked up. I am planing on running a stock alt with a 200ish alt so I can still use this s10 daily with no problems at idle. any help would be great.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
he should save that template hes gunna make, if he hasnt already, cuz at some point im gunna be doing a similar thing to my 2000 s10 blazer
Guest Just_Rob
We have a couple of different brackets that will fit the 4.3 V-6, but we've never had anyone try and wedge one in an S-10... We've done quads on a 4.3L V6 for that matter, but always in a full size... Room is the only limitation in an S10, mounting points etc are the easy part, just not much room in an S10 or S15... Would like someone to bring me a vehicle to find out... Rob
depends on where youre at. If youre around chicago, hells ya i would. I cant imagine it cant be done. A little persuasion and rearraging may be in order, but if you can drop a 383 in an s10 blazer (or pickup), yes ive seen them before, its sick, i cant imagine you couldnt find room for a 2nd alt.
For a s10???
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
00sdime00 (joe), made a triple alt bracket for his that he never even used. hes making a quad alt one now i believe.
I've got the triple bracket on it now. The 4th alt is going between my EDC and stock alt location.
Dual alts can be done but it's suuuuuper tight on a stock s-10...mine has new inner fenders and a bunch of stuff relocated or just straight up tossed.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
Do you have one made? And do you have any pic's???
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
