Well, i just bought this new head unit, and well, it doesnt have 3 pairs of preouts, only 2, front and rear. is it possible to hook up a sub amp still?? if so, how? and what would i lose?
Run the sub amp off of the rear.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Okay then, buy some RCA Y's and split the rear signal.
I do box designs.
will that effect the strength of the signal to each amp?
Depends on your HU output voltage, I would guess no. A lot of people run multiple amps off of the same RCA out put.
I do box designs.
just run your rear output to the rear amp, and then use the sub preouts on the amp
Read the first post again, he only has two out puts on the radio.
I do box designs.
read my post again. i said use the rear ouput for the rcas to his rear speaker amp, then take the preouts on his amp to his sub amp. sorry if you didnt understand me
my headunit has 2 pre-outs, one for the Front, and then one for the Rear. it has a feature where you can switch the Rear pre-out to work as a subwoofer preout or a regular preout.
