GORILLAslap Posted December 26, 2008 Report Posted December 26, 2008 someone told me u can get more power out of a 2 channel then a 4 channel for ur highs?? i just wanted someone to further explain how u do it an what makes it a better idea starting fresh, chrysler 300.. no subs amp nothin I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
Noobtastic14 Posted December 26, 2008 Report Posted December 26, 2008 ohms work on 4ch amps just like a mono amp. you could get more power per channel by wiring two speakers at 2ohm per chan rather than a 4ch amp at 4ohms per chan or you could get a 4ch amp and wire 8 speakers up 2 per chan and get moar speakers with moar powa BUT when doing 2 per chan you need to make sure the amp is stable at that load per chan and your staging will be weird (you lose either balance or fade when doing 4 speakers on a 2ch) best bet would be pairing two (two front right and two more front left) and getting double power double speaker while still having the staging. other options include 2ohm speakers or just a big 4ch that puts out losso power at 4ohms -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
Neo_frog Posted December 26, 2008 Report Posted December 26, 2008 someone told me u can get more power out of a 2 channel then a 4 channel for ur highs?? i just wanted someone to further explain how u do it an what makes it a better idea It depends if the 2-channel has a higher rating at 2-ohms than the 4 channel @ 4 ohms and they are both Class AB. I don't recommend running a 2-channel Class D amp on your highs. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
